HY78 123 ignition on a hy72 motor
- Kenteken: hy78,hy72
can an hy78 123 ignition be used on an hy72 motor? is there a special adjustment for the timing? the rotor arm on the 123 looks like it is about 15 degrees off from the s.e.v. distributor,will this make a difference in the timing?
many thanks to anyone who can help!
-gregor
-gregor
-lelijke Amerikaan
-lelijke Amerikaan
Re: onstekingstijdstip hy72 anders als hy 78
Is this the correct area to ask about 123 electronic ignition problems ? Can someone tell me where to look if it is not correct? Thank you
-Gregor
-Gregor
-lelijke Amerikaan
-lelijke Amerikaan
Re: HY78 123 ignition on a hy72 motor
Hi Gregor,
I'd say it would be the same, as the main difference is the cilinder volume, so timing should be the same. But I'm not sure... maybe contact http://www.123ignition.nl/id/8.html
Do you have the dip-switches on your 123? The manual sais which setting you need for the engine.
Thank you both , very helpful! This seems to answer my question, leipe
-gregor
-gregor
-lelijke Amerikaan
-lelijke Amerikaan
